Model vs Layout space dims
Luke_Daniels
Luke_Daniels
Can someone please help by suggesting the reason why my dimensions are tiny yet correct at 900mm in model space but correctly sized but scaled via the viewport (1:25mm) in the Layout (Paper) space?
cadffm
sounds you are using annotation feature (check your dim property "Annotation").
In model tab, change current scale to 1:50 for example.
See Statusbar, or CANNOSCALE setting.
Sebastian
Luke_Daniels
Hi Betreff, I'm using Standard dims and adding them only in the Layout view as advised. I can't change the CANNOSCALE from 1:1 for some reason also...900mm still showing as 1/25 of the actual value (36)
Luke_Daniels
DIMASSOC was set to 1 instead of 2 - solved thankyou
cadffm
Hi Subject,
- I'm using Standard dims
What are standard dims? (You don't need to answer, I just pointing to "there is no standard")
- and adding them only in the Layout
How can you see layout dimension in Modelspace? It's impossible.
- I can't change the CANNOSCALE from 1:1 for some reason
Because you can't change the cannoscale of paperspace,
I talked about MODEL TAB because if you see dims in model, we are talking about model tab content.
I missunderstood your case before. Your issue is about the dimtext only.
- also...900mm still showing as 1/25 of the actual value (36)
If dims are in paperspace, delete the old,
make sure dimassoc is set to 2
make sure you are using object snaps
(and make sure your dimstyle is set well)
Feel free to share a sample .dwg, this way it is much easier to help you
Sebastian
