Model space line weights
bonillapeara
bonillapeara
I opened a drawing I had been working on, and all of the line weights are showing as super thick.  Nothing has changed as far as the properties - they're all set to default, by layer, and I didn't make any changes to styles.  I tried updating AutoCAD, but it's still showing super thick lines.  Has something happened to my file? Is it recoverable?
0 Me gusta
Responder
Soluciones aceptadas (1)
28.904 Vistas
6 Respuestas
Respuestas (6)
No aplicable
Could you post the drawing?
0 Me gusta
pendean
Community Legend
Community Legend
Did you turn on DISPLAY PLOT STYLES in that pagesetup?
Or turn on LWEIGHT?
0 Me gusta
scot-65
Perhaps
command LWDISPLAY
and set to OFF.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
bonillapeara
I just tried changing my lineweight from "by layer" to 0.5 and the lines show up thin.  So somewhere my default "by layer" lineweight has been changed - where can I reset this?  It's happened in old existing drawings as well as a blank new drawing.
Thanks!
0 Me gusta
Valentin-WSP
Solución aceptada
Have you looked at the Lineweight Setting (right click the icon on the Status Bar) "Adjust Display Scale"?
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
bonillapeara
That was it!  Thank you so much, I'm not sure how that got changed, but that was definitely the problem.
0 Me gusta
