MLeaders Default Background Mask
cbmadrig
Observer
cbmadrig
Observer
Observer
Hello Evryone
I'm looking for a way to have all my MLeaders to have a background mask as a default. I don't see an option for it on the Multileader Style Manager
Anybody knows how to do this?
Responder
1.041 Vistas
5 Respuestas
Respuestas (5)
imadHabash
i think it's just an option exist in Properties dilaoge . see if it's ok with you .
Imad Habash
0 Me gusta
pendean
Community Legend
Community Legend
Create an MLEADER with that setting in place in a centrally located/pathed template file.
Copy it over to a template, then drag and drop it into all of your other files.
musson
Totally annoying that this property is not controllable in the Style. If you can set a text property in the object property palette you should be able to define it in the style. This property can be defined in dimension styles, why not MLeader?
What am I missing?
0 Me gusta
bobchandler2
Community Visitor
Community Visitor
SIR,
  THAT IS THE FIX FOR DOING THEM INDIVIUALLY OR ENMASSE.  I JUST ROLL WITH IT UNTIL I FINISH A SHEET OR PERIODICALLY.   I BELIEVE THE PREVIOUS QUESTION ASKED FOR A "DEFAULT TO BACKGROUND MASK"  AS A "DEFAULT".
IM NOT YELLING ITS A DRAFTING THING
pendean
Community Legend
Community Legend
@bobchandler2 wrote:
...ASKED FOR A "DEFAULT TO BACKGROUND MASK"  AS A "DEFAULT"....
Not everything in the program can be a default, but you could try the ideas already offered and others like
https://forums.autodesk.com/t5/autocad-forum/background-mask-default-settings-thru-registry/td-p/826...
0 Me gusta
