MLEADERALIGN Problem with leaders on right side
ramcharger318
ramcharger318
When MLEADERALIGN is run when the multileaders have their leaders on the right side, it aligns the left side of the body of text and doesn't align the starts of the leaders themselves, which is how MLEADERALIGN works the leaders are on the left side.
Anyone know how to get around this without having to mirror the objects first then align?
Replies (9)
pendean
Community Legend
Community Legend
What are the "right side" settings in MLEADERSTYLE and how do they compare the the "left side" settings?
ramcharger318
They are the same.  The only setting I see for leader side setting is how they attached to the text.
wispoxy
From a previous thread
a post from (Autodesk Support) MichaelBussiere2
Re: Multileader Align Problem
01-04-2012 09:39 PM in reply to: merrellr
In this case I have tested this MLEADERALIGN command in 2012 and see that per the MLEADERSTYLE it does respond as desired and align the MLEADERS as desired.  How are you applying this tool?  Have you verified the MLEADERSTYLE settings to ensure the desired output?  If you have a test file, would you be able to post it to compare results please?  Thank you and we look forward to your reply to further assist with this inquiry.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
ramcharger318
Please see attached file.  In the file, the multileadera are aligned how I would like them.  If you run the MLEADERALIGN command on multileaders on the right, nothing changes, however, if ran on the left, the leaders align to the left, and to the right.
wispoxy
Thanks for the sample.
pendean
Community Legend
Community Legend
They are not alike: the text on the left is LEFT justified, the text on the right is RIGHT justified (which looks exceptionally unprofessional BTW).
If I also select all the mleaders on the left and on the right, other than content they also differ in some many other ways no related to left/right (and you also have two mleaderstyles in use).
Try to make them truly identical and see if your desired behavior is accomplished.
As part of your testing, turn off leader extensions for a bit (these are also on in some cases and off in others).
ramcharger318
Thanks for your advice.  I copied one from the right side and mirrored it, and then tired MLEADERALIGN and it worked like it should.  I think the problem has originated from using a LISP that converts MTEXT and leaders into multileaders.
I'm going to search for a way remove all formatting from multileaders, unless you know how.
jp9ETNT
I have exactly the same issue I cant solve, please see image below, the left MultiLeader is a mirrored version of the Right. I cant get them to look the same!
Any help much apprecaited.
jp9ETNT
I've worked it out, there is an option in the properties for Left and Right attachment. Both need setting to middle of top line for them to work effectively. Mirroring or Copying doesn't give a true like for like copy which is what the issue is.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
