Mleader with annotative text not showing unless I explode it....
payingtoomuch
payingtoomuch
Have a pretty good undersanding of mleaders and annotative text.
New problem.
Have created some mleader styles and they are visible in model space but are not showing up in paperspace (correct viewport scale and the layer is on and not frozen. Does have an assigned layer state however but I've checked that too to make sure the layer is on.
So, I can see these styles in MSpace but when I switch to paperspace (and refresh) they are not showing up. Only way I can get them to show up is if I explode the mleader then everything in PS appears as it should.
Anyone have any insight into this?
imadHabash
Try the following:
  • Enter ANNOALLVISIBLE on the command line and set it to 1 to have all annotative objects display.
  • Turn on Annotation display from the Status Bar (bottom-right of the drawing window).
Imad Habash
payingtoomuch
Thanks Hamad. That got me to where I needed to be. Annoallvisible set to one is basically the same command as the architect scale "all visible" at bottom right of screen.... right?
Well that got me thinking. Went back into paperspace and the Annotation scale for the viewport was set to a different scale than the viewport scale..... wonder why?
So, normally the annotation scale would default to the viewport scale right? Is there a way that I can set this up this way as I never make them different.
Thanks for your help!
payingtoomuch
Really don't want to have to go through all these sheets and all these viewports and change this....
Is there away to correct all the viewports at the same time?
