mleader behind hatch only on xref files
leticia.campanelli
Message 1 of 8
leticia.campanelli
hi there,
I have a drawing with hatching and mleaders, simple drawing nothing special about it - but when I xref the drawing the mleaders are behind the hatch.
original
the base/original file is correct with mleader in front of the hatch.
Xref
I have sent the hatch to back, mleaders to front, draworderCTL is set to 3.
any ideas on how to fix this?
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Does a REGEN or REGENALL fix the display issue by chance?
Did you use HATCHTOBACK command in that file by chance?
Message 3 of 8
leticia.campanelli
yes, I have...it works fine in the original file.
it is something to do with the xref.
Message 4 of 8
CVADCE1993
Check the mleader colour in the attached drawing's xref layer properties. It's seems like hatch and mleader colour both are same in the second snip(xref attached drawing). Once done try REGEN.
Message 5 of 8
jcarver32AM4
If the mleaders and hatching are in different drawings, the xref with the mleaders will need to be brought to the front.
Message 6 of 8
cadffm
is your product up to date, which program is in use?
Please share a screenshot of dialog, command: ABOUT
Sebastian
Message 7 of 8
Valentin_CAD
@leticia.campanelli ,
Post the drawing or try the suggestion from this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 8 of 8
CVADCE1993
@leticia.campanelli  check the below image for an example. In the same way, check your xref layer properties in the attached drawing. hatch and mleader both are in grey. Change the mleader colour to other in the attached drawing's xref layer properties.
