Anuncios
MLEADER - Batch clear MTEXT formatting
awkeller88
awkeller88
I'm looking for a way to batch remove the formatting on MTEXT that is within a MLEADER, so that the selected style takes over.
We have a bunch of leaders that were copied over and over that had the right style but someone went in and changed the mtext to bold.
So far the only solution I have found is to individually select the multi-leaders, get into the text editor, select all the text, and clear the formatting. I have also considered just changing the text style to be bold to hide the problem. Would prefer a better fix. Thanks.
~Andy
0 Me gusta
Responder
Soluciones aceptadas (1)
12.979 Vistas
25 Respuestas
Respuestas (25)
The_Oak
I didn't create the sample, I sent one of the ones I found as an example as asked. Despite the Multileader being on layer TEXT (which is White), setting the Color to be ByLayer does not change the colour of the text, only the leader, as it has been edited to show as Yellow (not Bylayer).
As you note, StripMtext is not built to reset the colour of Mtext within a Multileader.
0 Me gusta
cadffm
Okay, but for other ones who not knows your problem, it would be better the mleader color is set to bylayer or to color red for example.
I saw the problem, also with the color yellow, but it's easy to overlook and draw the wrong conclusions.
Anyway, I was just trying to help Pendean, assuming he might not have seen it - that's how I interpret his answer.
Right
and not by object and not by everything you can controle now. right.
A cautious yes.
Again, just to make clear for other readers:
I note that StripMtext IS built for reset internal color formattings of MText, also inside a Multileader!
And you confirmed it You can create a Mleader, you can change the color inside the Mtexteditor.
SMT will remove them as expected.
But Yes: There is a Mtext-color property on Mleaders, which is normaly set to "color from mleaderstyle",
and SMT is not designed to change this setting.
Note: I don't know a "usual user way" to create an mleader like you posted.
If someone found a "normal way" (means without "hacks"), let us know.
Perhaps the issue was created by a tool, what is possible - but i don't know.
Sebastian
mian.ahmedSH9K6
I have AutoCAD 2023. Your LSP is not working. Please see attached. The height of the text should go to 0.0938 from 0.0625. I have done some one at time by right clicking it.
Thanks a lot for your help.
Mian
0 Me gusta
cadffm
mian.ahmedSH9K6
Thank you so so much. It worked on AutoCAD 2023. May God bless you.
Mian
0 Me gusta
awkeller88
@cadffm
Hello Sebastian. Just a big fan here :cara_con_una_leve_sonrisa:
Thanks for the update as well!!
Happy New Years.
~Andy
0 Me gusta
