Announcements
Misunderstanding of Transparency by Layer in Layout Tabs
Jeff10
Jeff10
HI Everyone,
I thought I understood the intent of using the transparency setting in Layers Property Manager; but, I guess I don't.
Here's what I would like to do:
1. Change the transparency of model space entities for the current viewport only using the VP transparency setting.
When I attempt to change the transparency of entities on a layer from within a layout I can change the transparency setting of the layer in question (for the viewport only); but, the objects on that layer don't change transparency.
The only way I can change the transparency is to change the transparency for the entire drawing (which then changes the transparency for all viewports).
If I draw objects in paperspace on the appropriate layers the VP transparency works like it's supposed to work (only for that viewport).
Is there are way to make VP transparency work for model space entities, or am I trying to make the program do something it's not intended to do?
Jeff
Replies (9)
imadHabash
HI,
i suggest to turn ON TRANSPARENCYDISPLAY (see attached image) while you're in VP.
Imad Habash
Jeff10
All of the conditions I mentioned were with TRANSPARENCYDISPLAY on.
Transparency works in the VP for entities drawn in paperspace (by viewport).
Transparency also works for entities in model space; but, those transparencies are the same for all viewports (everything in the drawing).
Changing the transparency of layers by viewport has no affect on the items in the model.
Jeff
john.vellek
Hi @Jeff10,
I have never really used the transparency by viewport so I played a bit with it this morning. I was surprised to see that the transparency did appear to change in all of them when I used VP Transparency. However, I found that if I did a REGEN in each viewport then the settings applied as expected. I am not sure if this is as designed but that should at least get things working for you.
John Vellek
Jeff10
Hi John,
Thanks for taking the time to look at the transparency issue.
I tried what you suggested regarding doing a regen. It didn't make a difference.
To keep it simple, what I did was change the transparency for one layer using the layout feature. The transparency changed correctly.
I then took a look at the drawing in the model space tab.
The transparency of the objects on that layer were reduced the same as on the layout tab.
I looked at the Layer Property Manager while in model space. The setting for the transparency of that layer was 0 (the value of transparency for that layer before I changed it in the layout tab. Yet, the objects were transparent.
I had to go back to the layout tab, then Layer Property Manager, to change the layout tab transparency back to 0 to restore the object (no transparency).
I also tried turning the layer off by layout tab, with the same results.
I'm not sure what's going on.
Any ideas?
Jeff
john.vellek
Hi Jeff,
To make sure we are on the same page, is it possible to attach a sample file for me to examine?  Please tell me the desired settings for the specific layer(s) in model space and for the specific viewports.
Which AutoCAD version are you using?
John Vellek
Jeff10
Hi John,
The drawing that I am having trouble with is pretty big (100+MB). I need to see if I can duplicate it on a smaller drawing.
I came across something else this afternoon. I haven't spent much time looking into other options; but, what I found was that if I had two layout tabs open the layout tab options in Layer Properties Manager didn't behave the same as when there was a single layout tab open.
I'll do some more experimenting later this weekend.
Take Care,
Jeff
john.vellek
Hi @Jeff10,
If your file is that big then AutoCAD might have some problems.  If I can provide you with an upload location are you willing to share the files so I can examine it? Or you can share it with me on your Cloud storage too. Whatever is easiest for you.
John Vellek
Jeff10
Hi John,
My apologies for taking so long to come back to the forum to follow-up on your last post. Basically, I have been so busy with other parts of one project that I haven't been able to spend much time trying to figure out plotting.
Working with the basic AutoCAD drawing, I am having success turning layers off in individual viewports. I think the key is changing the layer settings while in model space while in an individual viewport.
Maybe I should start a new thread about plotting. I'll make a couple statements in this thread, and you can let me know if it would be better to start a new thread.
I am having a tough time plotting with transparencies. The time it takes to plot with transparencies versus the time it takes to not plot with transparencies is significant. For the 100 MB drawing I mentioned, it will plot to .pdf in a couple of minutes. If I attempt to plot to .pdf with plot transparencies checked, it takes so long that after 10 or 15 minutes I just terminate the plot.
I know the drawing size is unusually large. It also has hundreds of layers. The problem is that I receive drawings like this from my customer to use as base drawings. I would like to plot most of the layers as transparencies. If I try to do that and then plot the drawings, the time is too great.
My customer has asked me to replot a large number of drawings because the detail that I add gets lost in the original drawing detail. I'm thinking that there must be an easier way to do this.
I think I will try screening/dithering; but, I will need to go back and change the colors for most of the work I have done, just so it's different from all the other colors in the drawing.
I would really like to use the plot transparency. I just don't think it will work properly given the size of the drawings.
Any thoughts?
(Sorry again that it too me so long to get back to you.)
Take Care,
Jeff
john.vellek
Hi @Jeff10,
I am glad that you came back to the thread.
Yes, plotting transparencies takes considerably longer as it is now rasterizing the content rather than retaining the simple vector geometry.
I would still like to see a sample file (even it is 100MB+)
Please let me know if this is possible. You can share via your cloud storage or I can give you an upload location too. Please let me know your preference.
In addition to the file, I would need the fonts, PC3 and PMP files and any possible xrefs. The easiest way to bundle this for me is to use eTransmit to create a ZIP file.
John Vellek
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
