Missing Textstyles
ym.56789
Missing Textstyles
ym.56789
Hi,  I am having some trouble with our firm's template.
I created a number af default styles, and they all are available from the properties dialog:
However, when I go into the Text Style dialog, many of them don't show up:
I'm stuck now - I can use the styles (they work fine), but I can't edit them.
If I make new styles the same issue occurs, I create a new style in the TextStyle dialog and it appears in the list of styles, but if I then create another new style, the previous style dissapears from the list. (Still exists, just not in that list.)
I will admit, I did use SuperPurge several times on the template, so perhaps that could have caused the issue?? Any help would be appreciated.
0 Me gusta
Responder
Soluciones aceptadas (1)
302 Vistas
2 Respuestas
Respuestas (2)
Kent1Cooper
Solución aceptada
We can see in your image that you have the Text Style dialog box set to display only "Styles in use."  Change it to "All Styles."
Kent Cooper, AIA
ym.56789
Thank you! That solved it.
0 Me gusta
