Missing points of reference osnap
Message 1 of 13
I am trying to align objects with the align tool but when I try to snap to corners no reference point is shown. I have  tried OSNAP and OSNAP tracking turned on  with all modes checked and only with endpoint and different combinations but nothing seems to work. It is a very simple design so I don't see a problem and I am noob here, I've read all the tutorials and watched all the videos and always the reference points appear like default but I can't see them. thank you in advance. I attach my file for you could see it.
Replies (12)
Message 2 of 13
jayhar
See this tread click here
This setting controls how close (in pixels) to the object you need to get before the object snap grips appear
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 3 of 13
Alfred.NESWADBA
Your uploaded DXF is not what we see on your screenshot.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 13
Paul_Gander
I'm guessing that you are referring to Autosnap markers and/or tooltips. (?) These can be switched on and off using the OPTIONS command:
From the image you posted it looks like you were snapping to Nearest or Perpendicular instead of Endpoint or Intersection but you wouldn't have known which without something being displayed.
Message 5 of 13
Thank you for your quick answer, I changed the aperture to 1, 40, 50, and several values but nothing different happens, still cant see the reference points.
Message 6 of 13
Alfred.NESWADBA
can you please create a video using Autodesk Screencast (>>>free download<<<), show us the behavior as well as the settings of the objects snaps?
- alfred -
Alfred NESWADBA
Message 7 of 13
Thank you for the clarification, indeed that's not the drawing, I am attaching it now.
Message 8 of 13
Thank you for answer, I uploaded my video, if you need more info please let me know. Thanks
Message 9 of 13
Message 10 of 13
SEANT61
Try with these.
May your cursor always snap to the location intended.
Message 11 of 13
Alfred.NESWADBA
sorry, that is a SPLINE, and this SPLINE does not have endpoints or midpoints where you are trying to catch an endpoint.
You might try to convert it to a PLINE (command _SPLINEDIT, but take care about the number of vertices then).
Ask the vendor of this drawing (seems not to be done with AutoCAD) why he used SPLINES for straight objects.
- alfred -
Alfred NESWADBA
Message 12 of 13
I made it with another program when I didn't have access to autocad, now that I have I am migrating everything and apparently it's not trivial, thank you very much for your help.
Message 13 of 13
Thank you very much, I understand now what was the problem.
