Missing Line type example
Message 1 of 17
I notice recently that when I clicked on the down arrow on the line properties ribbon that the line names show up, bu the actual line image thumbnails do not appear.  I am not sure if this may be an unintended consequence of a recent AC patch I installed, or I inadvertently hit a key stroke that affected this drop down list. I am attaching a screen shop for illustrative purposes.  Does anyone have any idea how to get my line type thumbnails back? Line Type Issue.jpg
Replies (16)
Message 2 of 17
rkmcswain
If you are sure nothing changed with your linetype file from which these are loaded (ACAD.LIN?), and this is happening in ALL drawings, then it almost seems like a display thing on the PC.
Is this a super high resolution display? Any other funky display things going on?
Message 3 of 17
To rkmcswain.
Thanks very much for responding to enjoy adequate resolution on my monitor, but I am using the same monitors I have been using for quite some time.  I am using 2 monitors.  When I move the AC window to the second monitor, I see (or not see) the same problem. When I click "Other" at the bottom of the drop down, it brings up the Linetype Manager panel, where all the linetype appearances are in place.  See attached screen shot as a paint file.  When I draw the specified linetype in the model space viewport, the line appears normal.  ????Linetype Manager.png
Message 4 of 17
john.vellek
Hi Michael,
Please type ABOUT at the command line and tell me your exact version of AutoCAD.
I am using AutoCAD 2017.1 Update.
If you reload all the linetypes from your .lin file does it display properly after that?
I am not sure which patch you applied but you can always try a Reset Settings to Default to see if everything comes back to normal.
John Vellek
Message 5 of 17
rkmcswain
Michael, I was not asking about your monitors, I was suggesting that maybe there is a quirk with the video driver and/or something with the way AutoCAD displays the linetypes in the Ribbon drop-down.
You did not answer the question about does it look like this in ALL drawings?
I also do not understand what you mean by “When I move the AC window to the second monitor, I see (or not see) the same problem” – Which is it? Does AutoCAD being on monitor 2 fix this issue?
As far as the other suggestions, depending on your answers above, I seriously doubt resetting your settings will fix this. Reloading the linetypes into the drawing is a benign step, but almost certainly not going to help either.
Message 6 of 17
john.vellek
Hi @Anonymous,
I am curious if you are using hi-res displays. This might explain what you are seeing.  Have you applied Update 1? This might fix the display issue.
John Vellek
Message 7 of 17
BIMologist_
Hi @Michael / @john.vellek
It seems like Michael is not the only one out there. Some else I know,also applied the 2017.1 (AutoCAD LT)  and are now missing the images.
RIBBONBGLOAD did not help
GRAPHICSCONFIG ON/OFF no luck.
1080p and 1600x900 monitors.
Tried Repair, Reinstall program and reinstall 2017.1. Also tried adding and removing Ribbon Combo Box. Also rebooted computer a few times.
No luck.
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
Message 8 of 17
John,
I am running dual monitors, both at 1920x 1080 resolution, at a refresh rate of 59p HZ. I have run all updates as they have become available and the issue still persists. So it's a mystery.
[maSmith logo graphic]
[email protected]
503-329-3248
"Styles come and go. Good design is a language,
not a style"
-Massimo Vignelli
Message 9 of 17
john.vellek
Thanks @BIMologist_,
I will get this logged as a defect ASAP.
John Vellek
Message 10 of 17
Thank you for looking into it.
[email protected]
503-329-3248
not a style"
-Massimo Vignelli
Message 11 of 17
BIMologist_
@Anonymous
Can you please tell me what is the OS and Build of the OS? and Graphics Card you have
If you run MSINFO32.exe the first page should have the relevant information.
BIMologist
- Nauman Mysorewala
Message 12 of 17
OS Name Microsoft Windows 7 Professional
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer INTEL_
System Model DQ77MK__
System Type x64-based PC
Processor Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Intel Corp. MKQ7710H.86A.0039.2012.0504.1937, 5/4/2012
SMBIOS Version 2.7
Windows Directory C:\Windows
System Directory C:\Windows\system32
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 24.0 GB
Total Virtual Memory 63.8 GB
Available Virtual Memory 55.5 GB
[email protected]
503-329-3248
Message 13 of 17
BIMologist_
@Michael @john.vellek
We can rule out Windows 10 anomalies that are plaguing tons of people.
1. Try to Reset your profile
https://pages.autodesk.com/AMERMultiIndustryFASTWBNNewSubscriber-82791_RegistrationPage.html?mktvar0...
2. Log in as another user and see if this issue persist? (The above should take care of it based on what she experienced with the new user.
I recommended this to the other user having the same issue and they said that the new user login profile does have the problem. she was hesitant to reset their profile.
If the reset does not help, post back with the export of your Registry HKCU\Software\AutoCAD.
Nauman
BIMologist
- Nauman Mysorewala
Message 14 of 17
john.vellek
Hi Michael,
Do you peer chance use the Light Scheme In your AutoCAD?  I am wondering if you change this to the Dark scheme if the linetypes are then displayed?
You can toggle this in Options>Display tab.
John Vellek
Message 15 of 17
dking
I also found this issue using AutoCAD Electrical 2017. Have installed SP1.  Changing to Dark color scheme brings the linetype examples back in the dropdown menu.
Is there a solution yet for the light color scheme?  I don't believe this was an issue in ACADE 2016.  (I've only migrated to 2017 in the past month+.)
Message 16 of 17
Yes. The latest 2917 AutoCAD update available on the Autodesk Desktop App took care of the problem of not being able to see the line type thumbnails in the Light color scheme. I am running AutoCAD 2017. When I switched to dark scheme a while back so I could view the thumbnails, I decided I liked it better and have not switched back.
Michael Smith
Message 17 of 17
Michael Smith
