Missing Layout Tool tab in AutoCAD 2022
brian.yamamoto9GKDR
Message 1 of 17
brian.yamamoto9GKDR
Does AutoCAD 2022 have the Layout Tool tab?
Replies (16)
Message 2 of 17
jrreid
Go to OP  (config)
Tab Display and check the Display File Tabs
Hope this helps.
JRR.
Message 3 of 17
brian.yamamoto9GKDR
Hi JRR,
I'm sorry, I do have that box already checked but it is not on my screen.
See below for screen shot.
Message 4 of 17
jrreid
oops. no screen shot showed up.
Message 5 of 17
brian.yamamoto9GKDR
Hi JRR,
I attached the email I sent.
Let me know if you see it.
Message 6 of 17
jrreid
How about this one?
Message 7 of 17
brian.yamamoto9GKDR
The boxes are all checked.
Message 8 of 17
brian.yamamoto9GKDR
Here is what I show on the Layout tab
Message 9 of 17
cadffm
Click on the blue tab [Layout].
But i thought you can not see the tab, but in your picture we can see the (blue) tab???
Current is START tab, click on LAYOUT.
Or is your question another one?
Sebastian
Message 10 of 17
cadffm
Sorry that i am confused now,
what is missing? (search a picture on www and post a link)
Your Layout Tab looks fine for me!?
Sebastian
Message 11 of 17
user181
Were you previously using something like Civil 3D or Map 3D?  I don't believe that tab is in plain autocad.
Message 12 of 17
brian.yamamoto9GKDR
Hi JRR,
I was only using regular AutoCAD.  I'm guessing AutoCAD 2022 doesn't have that Layout Tools tab?  That was my question to see if it did or not because I was trying to get to the Layout Elements section for the Legend, North Arrow and Scale
Message 13 of 17
cadffm
See user181 answer
>>"I was only using regular AutoCAD."
No, You didn't use AutoCAD20xx
>>"I'm guessing AutoCAD 2022 doesn't have that Layout Tools tab? "
Yes, and also older version of AutoCAD don't have a "Layout tools" tab.
>>" That was my question to see if it did or not"
Answered and solved.
>>"because I was trying to get to the Layout Elements section for the Legend, North Arrow and Scale"
Not part of Autodesk AutoCAD, install CIVIL3D as in the past
Sebastian
Message 14 of 17
jrreid
Maybe this is the view your going for?  But instead of Hide you would have to say Show.
Also if you want the large ones it is in the Arrow to the right.
I am kind of old school.. I type most commands (acad.lsp) or one click from commands.
Hope this helps.
JRR.
Message 15 of 17
pendean
Community Legend
Community Legend
@brian.yamamoto9GKDR OR...
You have to be in a layout first for the Layout tab in the Ribbon to appear: it's ALWAYS been like that, even in R2022.
HTH
Message 16 of 17
cadffm
for LAYOUT Tab, that is right.
for the LAYOUT TOOLS Tab that is right too,
but this Tab isn't part of AutoCAD (but C3D)
Sebastian
Message 17 of 17
brian.yamamoto9GKDR
Hi JRR,
Understood. Just wanted to confirm. Thank you for all your support.
