Missing Icons on Toolbars
Trying to set classic view on AutoCAD 2016. I've already done this on another computer and it worked fine, now doing it on a second computer and the toolbars come out blank with no icons at all. I've attached screenshots of the CAD 2016 that is working and the one that is not. Both computers are using Windows 10. Would appreciate any help!
imadHabash
would you please close your autocad and try to reset it to default settings . >> Click <<
Good Luck..
Imad Habash
rkmcswain
Before you reset the settings, which can be quite destructive, compare the support file search paths on each PC.
I suspect you may be missing one or more on the PC where the icons do not appear.
R.K. McSwain     | CADpanacea | on twitter
Thank you for your reply. How would I do this? Where do I look to see the search paths?
rkmcswain
At the command line, type in OPTIONS (or right-click and choose "Options")
Then click on the files tab.
Then expand the "Support File Search Path".
