AutoCAD Forum
Missing hatch patterns
4 REPLIES 4
1260 Views, 4 Replies
I am a newer autocad user and am having a issue of finding some hatch patterns in autocad architecture 2015. i need to locate my bought hatches and put them back in my cad program. any help ?? !?
4 REPLIES 4
doben
You can add them to the file support search path via the Options dialog (I assume it's similar to the one in vanilla ACAD) Please see attached.
in reply to: doben
Hello. Please Help, I am missing all hatch patterns. When I load and old file, then it gives me an error "missing shx file". the problem started when i wanted to upgrade my hatches in support   C:\Users\cat\AppData\Roaming\Autodesk\AutoCAD 2015\R20.0\enu
What can I do to fix it??????
Tags (1)
Alfred.NESWADBA
"SHX" is a filetype used by text objects or linetypes, has nothing to do with hatches.
What do you mean by "upgrade" my hatches, what have you done exactly?
If you have not done to much customizations you can reset AutoCAD profile to get your status back to default (>>>details<<<).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
pendean
Forma Design Contest
