Currently a student learning AutoCAD, however I have used the Design Center icon to bring images into my floor plan but all of sudden when I click the Design Center nothing happens. I don't even get the Design Center palette, I am wondering could I have hit some button that disables it? Need advise with anyone who has gone thru this same problem.
@Anonymous,
john.vellek has edited your subject line for clarity: student learning autocad 2017
You could check this and see if your issue is similar to that one:
https://forums.autodesk.com/t5/autocad-forum/design-center-missing/td-p/2772734
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
This can be frustrating but it sounds like the Design Center palette might be off your screen! A simple ALT-TAB might show the window. If you make it active (it still is not visible) you can then click on the task bar icon with a Shift and Rt-click. You can then select Move from the menu and use your cursor keys to move the window onto your screen.
The easiest way to show a "missing" window might be to rt-click on your task bar and select Cascade Windows.
