Missing CTB file !!
Missing CTB file !!
wimvdsac
Observer Observer
Missing CTB file !!
wimvdsac
Observer
Observer
Just wondering why ctb file settings are not included/saved within the dwg file ? (or at least a 'copy' of the last used plotstyle settings). I reguarly need to update dwg's and print to pdf again, and constantly the used ctb files are missing (due to dwg's originally created by third parties from which the drawing-creators are unknown to me). Being able to fall back on an embedded backup copy of the settings would save a lot of time.
S.Faris
This can be done if you request the 3rd parties to E-Transmit the drawing rather than sending the base dwg file.
SALMANUL FARIS
jayhar
CTB or STB file in AutoCAD is not found or missing click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
