Announcements
Missing browse/insert icon in blocks dialogue
When I open blocks dialogue window, I don’t have a browse/insert icon button.F7048769-FE3C-4FBD-B286-9BCF4A385C47.jpeg
imadHabash
The Libraries tab displays previews or a list of block definitions from a single, specified drawing or a folder. Inserting a drawing file as a block also imports all of its block definitions into the current drawing.
You can insert a block from one of these tabs with several methods:
  • Click and place a block into the current drawing. This method applies the settings specified under Options.
  • Drag a block into the current drawing for fast placement. This method only uses the Scale and Rotation values specified under Options.
  • Right-click and choose an option.
I suggest to click here to get more information . 🙂
Imad Habash
Alfred.NESWADBA
in addition...
You won't find the "Browse" button in the "Recent" tab.
This icon/button can be found in the "Libraries" tab there:
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
In addition to the suggestions from @Alfred.NESWADBA  and @imadHabash  you can use the "_classicinsert" command that will display the "old" block insert dialog window instead of the new "tool palette" version.
Is this what you are looking for?
