Misalignment problem
giovan_wurzius
giovan_wurzius
Community Visitor
Community Visitor
While I'm drawing, for example, a wall, everything is aligned, after I save and come back the wall is misaligned.
The red and green lines below should be the same, and the origin point of both lines is the same. The red line I´ve drawn after I noticed the problem.
dany_rochefort
@giovan_wurzius If everything is properly drafted as you say it was, i'm thinking a simple REGEN will fix the visuals.
You could also ID both endpoints of your lines to see if they are in fact the same coordinate or not.
But generally, the problem you describe is either a drafting mistake or a visual illusion. Lines are not offsetting themselves by way of a simple save operation.
RSomppi
This could happen if the lines are very far from (0,0).
