Mirroring Attribute Justification
Hey guys,
I have made some nifty blocks with all sorts of dynamic grips for our grading plans. The problem i am running into is the my attribute definitions are mirroring properly, but the justification isnt. I'd like to have it set up so that the text flips from left to right justification when i flip the flip the block, but it doesnt see, to be working correctly. I know I have done this before, but its a rough morning and I cant seem to remember how.
-A
leothebuilder
I've had the same dillema when making a elevation tag.
Could not get the text justification to flip from right to left.
I ended up using a visibilty parameter to change from left to right rather than a flip.
(visibility with the proper txt justification for right and left)
I did a little more digging and found that a multi-line definition will flip justification like I want. However, this means you now have to edit the attribute through the Enhanced editor, which is another set of double clicks. Not a huge deal, but when trying to sway the masses every litle work around hurts. Seems like there should be a simpler way.
-A
pendean
Community Legend
Community Legend
DYNBLOCKs have their own forum if you want to try there while you wait here: http://forums.autodesk.com/t5/dynamic-blocks/bd-p/154
