mirror objects over arc
prestin_unique
prestin_unique
Community Visitor
Community Visitor
Is it possible to mirror objects over arc or circle (I want to mirror the objects from inside to outside the circle)
cadffm
no, butween is regular, or?
it's easy to create by using ARRAY or ARRAYCLASSIC
Sebastian
Valentin_CAD
@prestin_unique ,
Might want to take a look at @Kent1Cooper suggestion here:
Use APPLOAD to load the attached LSP, then type MAO - see sample:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
EnM4st3r
i also tried to change Lee Macs Quick Mirror to do that
;; Original code by Lee Mac: https://www.lee-mac.com/quickmirror.html
;; Changed to try mirroring objects along a curve
;; Mirror SelectionSet about selected object
(defun c:QM   nil (QuickMirror nil nil))
(defun QuickMirror ( single delete / *error* _StartUndo _EndUndo doc ent ss sscount sel p1 p2 o ) (vl-load-com)
  ;; © Lee Mac 2011
  (defun *error* ( msg )
    (if doc (_EndUndo doc))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
    (princ)
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)
  (setq sscount 0)
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (if (or single (setq ss (ssget "_:L" '((0 . "INSERT")))))
    (progn
      (while (not ent)
        (setq ent (car (setq sel (entsel "\nSelect Mirror Object: "))))
      (while (< sscount (sslength ss))
        (cond
            (and sel
              (not
                (vl-catch-all-error-p
                  (setq p1
                    (vl-catch-all-apply 'vlax-curve-getClosestPointto
                      (list (car sel) (trans (cdr (assoc 10 (entget (ssname ss sscount)))) 1 0))
            (setq p2
              (polar p1
                (angle '(0. 0. 0.)
                  (vlax-curve-getFirstDeriv (car sel)
                    (vlax-curve-getParamatPoint (car sel) p1)
                1.
            (setq p1 (vlax-3D-point p1) p2 (vlax-3D-point p2))
            (_StartUndo doc)
            (if ss
              (progn
                (vla-mirror (setq o (vlax-ename->vla-object (ssname ss sscount))) p1 p2)
                (if delete  (vla-delete o))
              (progn
                (vla-mirror (setq o (vlax-ename->vla-object (car sel))) p1 p2)
            (setq sscount (1+ sscount))
            (_EndUndo doc)
  (princ)
Kent1Cooper
You can use the MAO command in MirrorAcrossObject.lsp, >here<.  [Oops -- someone beat me to it....]
Kent Cooper, AIA
illusionistNUGXG
It can be done with ease, if you redraw them this way:
Create a block with one of these arrow-things. The attachment point of the arrow are 0.0 coordinates in the block.
The arrow should face up or down.
Place the block along the circle with DIVIDE - select block (and write the name of the block) - allign yes - type in the amount of arrows you want.
Now you can change the direction of the arrows by opening the block and rotate all by 180°.
(Just be careful if you have this setting multiple times. Rotating the arrows this way will affect all circles.)
EDIT: oh...if the arrows (or whatever objects you drew in the block) are not symmetrical, you might need to mirror them in the block, not rotate.
