MINSERT Using VBA
MINSERT Using VBA
MINSERT Using VBA
Hello All,
I am writing a simple line of VBA Code that simply will not cooperate.
No matter what I do, when the command executes it dose not behave as expected.
For some reason when the code executes it acts as if the is one to many VbCr statements when I cant find one.
Below is the lien of VBA code and the result from ACAD command line.
ACAD 2017
Any help greatly appreciated.
The Code:
ThisDrawing.SendCommand "._minsert " & " BlockName " & vbCr & " 0,0,0 " & vbCr & vbCr & vbCr & " 5 " & vbCr & " 5 " & vbCr & "65.11" & vbCr & "39.31" & vbCr
The Output from ACAD Command Line:
Command: ._minsert Enter block name or [?]:  BlockName
Units: Inches   Conversion:    1.0000
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]:
Point or option keyword required.
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]: 0,0,0
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>:
Enter Y scale factor <use X scale factor>:
Specify rotation angle <0>:
Enter number of rows (---) <1>:
Enter number of columns (|||) <1>: 5
Specify distance between columns (|||):
Requires numeric distance or two points.
Specify distance between columns (|||): 5
Command:
65.11
Unknown command "11".  Press F1 for help.
Command: 39.31
Unknown command "31".  Press F1 for help.
Problem solved. For anyone who is interested, see blow for using Minsert in VBA.
Signature
RetVal = object.AddMInsertBlock(InsertionPoint, Name, XScale, YScale, ZScale, Rotation, NumRows, NumColumns, RowSpacing, ColumnSpacing [, Password])
