Migrate Custom Settings.
cloweRE8TC
cloweRE8TC
I'm using AutoCAD2026 & need to migrate custom settings so that I can also work from home, but I get an XML error is there a fix for this?
AutoCAD does create the ZIP file AutoCAD 2026 - English_cust_settings, so is the message itself an error?
BhaskarMurari
@cloweRE8TC Have you tried to manual migration:
Manual migration (Alternative option 2)
In this example the migration will be done from 2020 to 2023 in plain AutoCAD.
  1. Make a backup of all affected 2020/2023 folders.
  2. Start AutoCAD 2020 and open the options.
  3. Switch to tab "Profiles" and export the current profile as an ARG-file.
  4. Open Windows Explorer and go to these two folders and copy the content of these folders:
    • C:\Users\<user name>\AppData\Roaming\Autodesk\Autodesk AutoCAD 2020\R23.1\<language code like "enu">
    • C:\Users\<user name>\AppData\Local\Autodesk\Autodesk AutoCAD 2020\R23.1\<language code like "enu">
  5. Paste and replace content of these folders:
    • C:\Users\<user name>\AppData\Roaming\Autodesk\Autodesk AutoCAD 2023\R24.2\<language code like "enu">
    • C:\Users\<user name>\AppData\Local\Autodesk\Autodesk AutoCAD 2023\R24.2\<language code like "enu">
  6. Open AutoCAD 2023 and open the options.
  7. Switch to tab "Profiles" and import the formerly exported ARG-file.
cloweRE8TC
That worked perfectly thanks Bhaskar.
