Anuncios
Middle button as a Snap Menu
No aplicable
There has been lots on information on how to turn the middle scroll wheel as pan. I use the middle button for a snap menu instead. I despise the middle button as a pan option. Anyhow, Mbuttonpan is set to 0, I have exhausted all efforts to try to get my snap menus back as my middle button. How do I get my middle button snap menu back. I have been using the snap button menu for the last 15 years, so learning to use the pan function does not work for me.
Responder
Soluciones aceptadas (1)
3.159 Vistas
10 Respuestas
Respuestas (10)
Patchy
Can't go back a decade ago, hold the shift key or Ctrl key down and middle button that's all you get.
0 Me gusta
No aplicable
I had a computer upgrade in the last couple of weeks, The CUI file has been changed. I am still running the same version, just on a different machine. It worked 3 weeks ago it should still work. While I appreciate the sarcasm, the problem remains in the CUI changes. Shift-click does nothing either.
0 Me gusta
Patchy
There is a setting called RESET to Default, have you tried to use that option?
0 Me gusta
No aplicable
Yes I have, Right now if I push the middle button, the Aperture & Cross hair go off when I hold the button down, they come back when I depress it.
0 Me gusta
RobDraw
When I change MButtonPan to 0, I get the shortcut menu. Tested in MEP 2020 and LT 2020. Maybe it's a mouse setting.
BTW, pushing the button and depressing it are the same thing.
Rob
0 Me gusta
No aplicable
The mbuttonpan is set to 0, that's whats so confusing about it. It's not a mouse setting either, tried that one.
0 Me gusta
RobDraw
The behavior you want is default when MButtonPan is turned off. Since you reset to default settings, I am leaning towards your new hardware.
Are you running any vertical products?
Do you get any menus when you right click?
Rob
0 Me gusta
No aplicable
I will be re installing the version and will remake all my custom settings hoping it will reset back to the default settings in Cad.
0 Me gusta
RobDraw
I wouldn't go all nuclear, yet, but that's up to you.
I did ask a couple questions that might reveal what the problem is. Would you care to answer them?
Rob
0 Me gusta
No aplicable
Solución aceptada
I have reinstalled 2020 and it works fine now, when it was initially installed the settings were migrated over from 2017. The middle button now has the snap menu.
0 Me gusta
