Messure point clouds in room from bottom to top!
Hey! Could someone please show easiest way to messure a room. File in attachment! Save my day! 🙂
Kent1Cooper
[No attachment....]
Not dealing with point clouds, I have to ask their nature.  Is a point cloud just a bunch of independent Point entities, or is it some kind of object type of its own?  If the former, there are routines around to find the overall extents of a selection of multiple objects, and the Y-coordinate difference in the extremes would tell you the top-to-bottom extent of all the Points.  If the latter, is it an object type from which one could get the bounding box?  If so, again, the Y-coordinate difference between the minimum and maximum corners of the bounding box would tell you.
Kent Cooper, AIA
Alfred.NESWADBA
please find a video that shows how to use 3D-ObjectSnaps with it's point-cloud options!
More to be read >>>here<<<
The video shows a simple sample, using command _DIST between 2 planes on the point-cloud
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
What I need to do extra to see my measures in drawing like this?
Alfred.NESWADBA
best would be a block, with an attribute + a solid hatch behind the attribute (or you use a multiline attribute, that can have an automatic background mask).
- alfred -
Alfred NESWADBA
