Mesh modeling with symmetry
ja1357
ja1357
Hi
Is there a way to model a mesh in symmetry in real time?  In Maya there is a command that allows symmetry modelling and thought AutoCAD would have the same feature.
Just to be clear what I am wanting to achieve; I create a box mesh, then select a face on any side and move it 50mm in the direction of its normal and would like the opposite face to also move 50mm in the direction of its normal.
I don't like doing things twice so I modelled only half of the mesh and mirrored it but now I cant union them together so now I have two issues
1.  Is there a way to model a mesh in symmetry?
2.  Is there a way to union two meshes together?
0 Me gusta
Responder
Soluciones aceptadas (1)
783 Vistas
5 Respuestas
Respuestas (5)
imadHabash
>> Is there a way to model a mesh in symmetry? <<
as you ask... there is NO way.
>> Is there a way to union two meshes together? <<
Union command is not supported for mesh objects and you have to convert it to 3D solids.
Imad Habash
0 Me gusta
ja1357
Thanks imadhabash
AutoCAD mesh modelling sucks
0 Me gusta
john.vellek
Hi @ja1357,
There is Merge face - not quite the same thing as Union but can help in some situations.
John Vellek
0 Me gusta
john.vellek
Hi @ja1357,
I am checking back to see if my post or @imadHabash's helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
ja1357
Solución aceptada
I will try creating half the mesh model, convert it to a solid, mirror, union, then convert to mesh.  The merge face wouldn't be a suitable option in this case but thanks for your help.
0 Me gusta
