Anuncios
Mesh Geometry Export to a Spreadsheet
ata
Community Visitor
ata
Community Visitor
Community Visitor
I have a zero thickness 3d mesh with 49 verticies. I want  to export the Vertex X, Y, and Z data into a spreadsheet for analysis. I can manually copy the data for all 49 but was hoping for a better solution.  Any ideas?
0 Me gusta
Responder
213 Vistas
1 Respuesta
Respuesta (1)
leeminardi
There's probably some program available to so this but using just AutoCAD I would explode the mesh then give the LIST command and copy the output to Excel.  This would result in something like this:
After using Excel's Text to Columns with "space" specified as the delimiter it would look like this:
Delete the extraneous columns and rows and you are all set except that you will have duplicate vertices. I have a procedure that can identify duplicate points while maintaining the order of the data.  Let me know if you are interested and I will write it up.,
lee.minardi
0 Me gusta
