Measurements & Scale
Editing existing drawings, new dimensions are not the same scale as existing.
TheCADnoob
are you dimensioning in paper space or model space? how old is the existing drawing?
CADnoob
Alfred.NESWADBA
My questions are as short as your problem description 😉
  • same dimension-style`?
  • same dimension-scale?
  • same space (model- or paperspace)?
  • same annotative settings?
The more info you can give (and maybe the drawing itself) the more and faster helpful we can be!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I am drawing on an existing drawing, on Autocad 2018, but when I "Scale" my
line to match the existing, it is TOO BIG/LONG so it doesn't fit the page.
Tried a few things in dimensions, but nothing.
Alfred.NESWADBA
>> Das ist der Modellbereich
Can you please upload the drawing, with a marker so we can see where is the line you wanted to draw as well as which length it should have.
- alfred -
Alfred NESWADBA
FYI, I have the printed 24x36 drawings, it says 1/8" = 1'-0"
On AutoCAD:
Existing drawing= 6'-0"
If I draw over it )measurement above) it says= 0'-3/4"
I am new to AutoCAD, having trouble switching around the Annotations,
Scaling, and Measuring.
