MEASUREGEOM does not match results from DIM
10:56 AM
I am working in AutoCAD 2D model space on a dwg file provided by an architectural draftsman. Dimensions produced by the DIM command seem correct compared to the pdf file I was provided with. However, when I try using the Measuregeom tool, results are inaccurate by slightly more than 100% larger measurements. I use the Measuregeom tool regularly, I have no idea how to correct this so I can use the tool when drawing. I appreciate your thoughts. Thanks!
