Match Property not work
Dear All hope you are doing well.
Issue is that: When I am trying to math the properties of hatch its not matching properly.
Please help me
I will be thankful.
vinodkl
When using "MATCHPROP" first select the source object and then select "setting" from the command line and check if there is a check-mark for Hatch in special properties.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
