Mark (copy) parts of a block, wihout exploding it
mmatanlevi
mmatanlevi
I have a drawing with a block in it. This block contain many objects. Just for example let's say that this block is a dimensions annotations all around the drawing. I want to copy parts (multiple parts, not just one object) of this block to another drawing. As far as I know I can copy it, then explode it, and then delete the parts I dont need. Or use the Copy Nested Objects (NCOPY) but I can only click on objects with it, one by one, without an area-selection marking option. Do you have a method to mark (with area-selection tool) multiple object of a block?
Thank you
cadffm
you can copy objects while in block edit mode,
Command: RefEdit
Refclose without saving
(But explode, copyclip, undo, works as well)
Sebastian
mmatanlevi
Hey, thank you.
I click REFEDIT but cant copy. Here is the error:
cadffm
My fail
If the insert-scale is not important, try the same in BEDIT instead RefEdit.
Sebastian
pendean
Community Legend
Community Legend
@mmatanlevi There is no "... multiple blocks selection to extract content from them all at once..." tool in AutoCAD. Sorry.
One by one is all you get.
