Maptrim Function
redasobeh
Maptrim Function
redasobeh
Where did "Maptrim" Function go in AutoCAD 2022?!
Why is it become not available?!
Replies (16)
ennujozlagam
check here previous thread and see if helps. thanks
redasobeh
CMDDIA Command didn't solve that!
I converted its Value From 1 to 0 but "maptrim" still not available!
Pointdump
MAPTRIM is not available in Vanilla AutoCAD. It's only in Map 3D and Civil 3D.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
redasobeh
maptrim was available in autocad 2018, 2019, 2020, 2021
j.palmeL29YX
Not here.
Please post your "About" window.
Maybe you have running a (automatic loaded) LISP in the old versions (?).
Jürgen Palme
redasobeh
No any Lisp,
it is the same "maptrim" Command in civil 3D,
it was provided to Autocad started from Version 2018.
ВeekeeCZ
You're very likely run C3D/MAP as AutoCAD which includes many functions from MAP.
j.palmeL29YX
As long as we don't see his About window we can endless continue guessing ...  😉
@redasobeh :
In an "AutoCAD" where the maptrim command works for you start the about command and show us a screenshot of the About window please (as I have already asked >>above<<).
Jürgen Palme
ChicagoLooper
From C3D=>Change workspace to Planning & Analysis=>Tools Tab=>Map Edit Panel=>Boundary Trim icon
Chicagolooper
pendean
Community Legend
Community Legend
ABOUT command in your R2021 will confirm which program you are actually running for an AutoCAD variant.
Likely you (or your IT) did with your earlier version, you forgot to install MAP3D2022, aka the free/included Map3D Toolset (dumb name for a separate program), here is how to do it https://blog.procad.ie/autocad-2019-installing-specialized-toolsets
Or... you subscribed to the wrong program and needed Autodesk Civil3D with is not included for free in the AutoCAD Subscription as a toolset. Civil3D trial and purchase can be done from here https://www.autodesk.com/products/civil-3d/overview
Or you had some 3rd party add-on in R2021 with that command.
HTH
redasobeh
Here is The Description of "maptrim" Command (Autocad v.2021),
with noting it was in AutoCad started from V.2018 up to v.2021
I need it in Autocad Because I use "AutoCad" more than "Civil 3D",
my question is: Why that Command was terminated?
ВeekeeCZ
Men, DO you even READ what we ask of you?
That screenshot does not prove anything. What do you think I am having?
It's C3D!!! In this "as AutoCAD" profile.
You're wasting our time.
pendean
Community Legend
Community Legend
Post a screenshot of your ABOUT command pop-up from 2021 and 2022: why are you afraid to do that?
Go on, prove us wrong the correct way 😉
ChicagoLooper
Open Civil3D and you'll be able to access the MAPTRIM command from the ribbon. Don't use Civil 3D as AutoCAD. See image below.
From C3D, go to Tools Tab=>Map Edit Panel=>Boundary Trim Icon.
If you are using AutoCAD instead of Civil, then you'll need to invoke MAPTRIM from the command line because it is NOT available from the AutoCAD ribbon. The MAPTRIM command wasn't terminated--it's still available when you use the command line. Civil 3D as AutoCAD (plain vanilla version) doesn't give you access to the Civil 3D ribbon.
Chicagolooper
redasobeh
Thanks for your response and your participation,
I never imagined that the discussion of the topic would reach such a way of responding,
I am so sorry for wasting your time,
But I am here to learn from the members and my mistakes.
redasobeh
I have always used the AutoCAD program as a part of Civil 3D (Civil 3D as AutoCAD),
In the versions from 2018 to 2021, I used command (maptrim) and it was unavailable before version 2018,
While installing this version Civil 3D (2022), it was not there an option for installing (civil 3D as AutoCad) as was happening previously.
I installed AutoCAD separately, And I think that caused some confusion for me.
