Managing Xref Layer Property Overrides with a Nested Xref Tree
I am trying to establish a best practice for controlling layer properties for consultant bases (xrefs), something I've done many ways over the years so I'm trying to reflect on that and recommend a preferred method.
Option 1: Currently (Co Standard) we manipulate the layers directly in the consultant/external file once it is received (change color, linetypes, etc.).
- Pro: The benefit is that these changes we make "ripple" through the rest of the set including the our working files and sheet files.
- Cons: Brings up concerns about authorship / editing another entity's data. Also it is a bit of a process and makes integrating updated xrefs a bit of a chore. Some people will even copy and paste the data from the new file into the old to maintain the path structure and overrides which creates opportunities for errors.
Option 2: Another option is to not edit the xref at all when received, but simply re-path to the new version and control the display independently in our working files and sheet files.
- Pro: zero to minimal changes to an external consultant's data. Fast to integrate the new data.
- Cons: Need to adjust the layer property overrides independently in our sheet files (which are broken up by series) and working files. This part can be time consuming and lead to graphic inconsistencies across the set if not done correctly.
Option 3: To be honest I'm not sure this is even an option but I'm hoping to find a compromise (best of both worlds) solution though so far I'm striking out. We have an aggregator file (called xBase) which collects all the consultant xrefs as attachments and then this file is xref'ed as an overlay into our sheet files and working files. It would be nice if we could manipulate the xref layer properties in this xBase file and the overrides could update in our sheets and working files. I was hoping that through VISRETAINMODE or a similar command this could be implemented but it doesn't look like the aggregator host file (xBase) will affect the layer properties of the xrefs in a way that carries on to the sheets and working files as I hoped. I watched this 8 year old video (Power Triad 2017 ) hoping to get some answers and I think the question asked at about 46 mins gets to my question but the presenters don't seem to offer an answer. Maybe Layer State Manager is another tool we could use, but I'd need to do more research on how to implement that.
I understand this may be a company preference issue but would be curious if Autodesk or others have any guidance / AEC industry standards.
Thanks!
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
