Making the file path appear on the drawing
How do you make the file path appear on your drawing? I need it to be live, so if the drawing ever gets moved the file path will automatically change and I can look on the printed plans and see the location of the file?
Alfred.NESWADBA
you can use command _FIELD (>>>details<<<) to embedd the save-path of the file in your drawing.
You can also use the field option to include fields in text, in mtext, in attributes.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
S.Faris
You can check the PLOT STAMP option in the print dialog, and then choose Drawing name.
PLOTSTAMPPLOTSTAMP
SALMANUL FARIS
