Making Diameter Dimension Text Horizontal Independently
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Good day AutoCAD Users Worldwide and Autodesk employees I am battling to find a way to make Diameter Dimension Text horizontal independently of the Linear Dimension text. Does anybody know of a way? Is it possible in AutoCAD. I know how to do it in Inventor (see attached 2 jpegs - the first one showing my attempt in AutoCAD, the second one - how it is done in Inventor Michael Kovacik 2d & 3d Autocad and Inventor designer/draughtsman . (Manufacturing/mechanical/Structural)(34 yrs) Autocad (21 yrs) Inventor (9 yrs) . Autodesk Product Design Suite Ultimate 2018 Autocad 2018, Inventor Pro 2018 (personal licensed copy) . Johannesburg, South Africa . (Impossible only means you haven't found the solution yet)
S.Faris
Hi, Did you try using ISO Standard for Text Alignment?
SALMANUL FARIS
MikeKovacik4928
Thanks Salmanul
Should have tried it, it was the only other button available!
Mike
