Making Custom Shortcut Keys to set custom layers as current
Hi Everyone,
I am working on improving our drafting workflow using custom keyboard shorcuts to manipulate layers. I already have made ones to turn our custom layers on and off like so:
Made a custom command called "SymbolsON" with the macro "^C^C-layer;on;1_CFSE_ruff_Symbols;;" and assigned it the key combination of 'Shift+1'
This works just fine, but now I need to make a shortcuts that make our custom layers current so I can quickly change between them without using the pull down menu.
If I type "-layer" (enter) "set" (enter) "1_CFSE_ruff_Symbols" into the command line it works fine so I made a new command called "MakeSymbolsCurrent" with the macro "-layer;set;1_CFSE_ruff_Symbols::" and assigned it the key combination of 'Shift+U'
Here's what I don't understand: The first time I hit 'Shift+U' it brings up the CUI pop up and regardless if I click 'OK' or 'Cancel' it switches the current layer to the one. After the first time it gives an 'invalid option keyword' error after -LAYER.
If I go back and open the CUI and highlight my custom "MakeSymbolsCurrent" command, then click ok it will repeat the process of opening the CUI pop up window if I press the assigned shortcut.
I'm using Autocad LT 2018 on Windows 10 if that matters. I have also attached two screen captures.
Can anyone help?! This doesn't make sense to me.
Thanks!
