Make Plines thicker
Make Plines thicker
Make Plines thicker
All I'm looking for is an easy way to make my existing polylines thicker, as they are hard to see when zoomed out of my drawing.  If I select a line and change the thickness of a somewhat basic shape I get all these newly generated lines crossing over a bunch of times. What am I doing wrong?
Kent1Cooper
Are you confusing thickness with width?  Thickness is "up off the page" into the Z direction, and can be applied to Lines as well as Polylines and lots of other entity types.  Width for Polylines [not applicable to Lines or other things, not even 3D Polylines] is what would make them easier to see when Zoomed out.
Kent Cooper, AIA
imadHabash
you can get your polylines thicker and visually as i understand from your post by using Lineweight  from Layer command line.when you add and change lineweight and LWDISPLAY is ON you will get what you ask for.
I hope it's help..
Imad Habash
Yes, I was confused with the wording.  I'm trying to get my polylines to have more width
