AutoCAD Forum
Make dwl visible when opening a dwg
6 REPLIES 6
salbrechtJHHCV
402 Views, 6 Replies
Anyone have a way to make dwl files visible in ACAD open dwg dialog box... then I could see if somethings open before opening.  Why?  Well, because I use dropbox & don't want to view them in explorer every open.
Thanks all :o)
6 REPLIES 6
paullimapa
in reply to: salbrechtJHHCV
Since AutoCAD’s open file window only shows supported file types like dwg and dxf, it won’t be able to show any other unsupported file types.
Also you may want to invest in alternative online services that support dwg file locking
Paul Li
IT Specialist
@The Office
rkmcswain
Sure - in the file dialog box, in the "File name" field, type in *.* and tap the Enter key.
You'll see ALL files including .dwl
FYI: Neither the presence or absence of the .dwl and .dwl2 files is a valid indication that a file is in use.
R.K. McSwain     | CADpanacea | on twitter
pendean
@salbrechtJHHCV Since you need to use DropBox with others for file sharing, explore options like https://dropbox.tech/developers/file-locking-using-the-dropbox-api
and https://protekitsolutions.com/how-to-properly-handle-files-in-dropbox-to-prevent-duplicate-or-confli...
PLUS you can always purchase 3rd party tools like https://toolbox.easeus.com/file-lock-tips/password-protect-dropbox-folder.html#:~:text=Method%202.%2... (I am not affiliated with them in any way, just one of a few options out there)
salbrechtJHHCV
in reply to: rkmcswain
Well I'll be dipped... just (1) asterisk and a quick enter & - Whoop there it is!  Not trying to tell anyone to use this method.  But this will be useful for me how I operate.
Thank you!
paullimapa
if you're interested in running a lisp function OPN that replaces AutoCAD's OPEN window with one that by default lists all filetypes with *.dw?:
; OPN replaces AutoCAD's Select Open window with another that initially shows files with *.dw? extensions
; OP:
; https://forums.autodesk.com/t5/autocad-forum/make-dwl-visible-when-opening-a-dwg/m-p/12280372
(defun c:opn (/ aec_openp fil)
 ;;;--- aec_openp function
; checks to see if file is open already by another program
; returns T if file is opened or read-only
; https://forums.augi.com/showthread.php?6102-Detect-Read-Only-file-attribute&highlight=open
; Usage:
; (aec_openp (strcat(getvar"dwgprefix")(getvar"dwgname")))
; Returns:
; T
; Usage:
; (aec_openp "C:\\Autodesk\\Floor Plan Sample.dwg")
; Returns:
; nil
 (defun aec_openp (file-arg / file)
  (cond
   ((setq file (open file-arg "a"))
        (close file)
  (not file)
 ) ; defun
 (if(and(member "acetutil.arx"(arx))acet-ui-getfile)
  (setq fil (acet-ui-getfile "Select Drawing File to Open" (getvar"dwgprefix") "dw?;dxf" "" 288))
  (setq fil (getfiled "Select Drawing File to Open" (getvar"dwgprefix") "dw?;dxf" 4))
 (if fil
  (if
    (and
     (not(aec_openp fil))
     (zerop(getvar "SDI"))
     (or
       (wcmatch (strcase fil) "*.DWG")
       (wcmatch (strcase fil) "*.DWS")
       (wcmatch (strcase fil) "*.DWT")
       (wcmatch (strcase fil) "*.DXF")
   (progn
    (vla-open (vla-get-documents (vlax-get-acad-object)) fil :vlax-false)
; https://www.cadtutor.net/forum/topic/50535-switch-between-opened-drawings-vla-activate/?do=findComment&comment=419633
    (vlax-for doc (vla-get-Documents (vlax-get-acad-object))
     (if (eq (vla-get-fullname doc) fil)
      (vla-put-windowstate doc acmax)
      (vla-put-windowstate doc acmin)
   (alert(strcat"\nSelected file is Not a Drawing or is Already Opened:\n\n[" fil "]"))
  (princ"\nNothing selected.")
 (princ)
Paul Li
IT Specialist
@The Office
salbrechtJHHCV
in reply to: paullimapa
Thanks. Maybe I'll give this a try as well.
AutoCAD Inside the Factory
