[macro] - Select previous and select last
Intuos5
Intuos5
This may have been asked before, but I haven't found the answer yet.
Are the select last and select previous commands available to assign a macro to? I see them listed under CUI for shortcuts, but they do not appear under the listed aliases. Or do I need a LISP for this?
I need this rather than typing "p" or "l" within a command, since I need to reselect dynamic blocks to have the grips appear.
0 Me gusta
Responder
Soluciones aceptadas (1)
2.010 Vistas
10 Respuestas
Respuestas (10)
SeeMSixty7
you can try this.
(sssetfirst (setq myss (ssadd (entlast) (ssget "P") )))(sssetfirst nil myss)
0 Me gusta
Intuos5
Sorry for the somewhat late reply, I didn't have the time to check how I could turn this into a saveable LISP script. Now that I did look into the matter, I wasn't fortunate enough to stumble upon a solution. Could you save it as LISP or post a link to a guide so I can have a try?
0 Me gusta
Kent1Cooper
This is enough, in my trial:
(sssetfirst nil (ssget "_P"))
I put it into a Tool Palette button, and just picking on it selects/grips/highlights the Previous selection.  And likewise for the Last item:
(sssetfirst nil (ssget "_L"))
Kent Cooper, AIA
Intuos5
Apologies for asking yet another thing, this is all new to me. Okay, so for creating the new command, in which box do I paste the script portion? I presume the macro one for the command? Then I can use this guide to assign the actual alias to the command, which looks doable.
0 Me gusta
ВeekeeCZ
You never said how you want to run the macro/lisp. By typing some letters?
0 Me gusta
Intuos5
Now that you mention it I indeed didn't mention it in the OP, my apologies. I want to type in an alias (so just letters).
0 Me gusta
Kent1Cooper
In the procedure in that guide, yes, put the code into the "Macro" slot, and the letters you want to type into the "Name" slot.  There are other ways, but that should do it.
Kent Cooper, AIA
Intuos5
Okay now that I had some time to configure this, I got the command working using a keyboard shortcut, however I couldn't figure out how to add it as an alias. I tried the method of typing the command in the .pgp file, but it doesn't show up in the alias menu, nor does the alias I specified activate the command. Could someone lend me a hand to configure select last and select previous to have "sell" and "selp" as alias? I can always change it later, if only I knew how it works.
0 Me gusta
Kent1Cooper
Solución aceptada
@Intuos5 wrote:
... how to add it as an alias. .... Could someone lend me a hand to configure select last and select previous to have "sell" and "selp" as alias? ....
Aliases in the .pgp file are for native AutoCAD commands.  For this, you would want to define little custom command names:
(defun C:SELL () (sssetfirst nil (ssget "_L")))
(defun C:SELP () (sssetfirst nil (ssget "_P")))
You could put those lines into your acaddoc.lsp file [make one if you don't have one, even if they are all that's in it, in a place where AutoCAD knows to look] and they'll be loaded and available in every drawing.
Those can be used "plain" at the command prompt to select/highlight/grip the appropriate thing(s) as pre-selection for use with a subsequently-invoked command, but they can also be used transparently, i.e. within a command that's asking for object selection, mixed in among other selection options, by typing them with an apostrophe prefix:
Command: MOVE
Select objects: {picked something other than the last object} 1 found
Select objects: 'SELL
(nil <Selection set: 174>)
1 found, 2 total
Select objects: {continue selecting things...}
[though in that kind of usage, a simple L or P will do the same, but you could put them into Tool Palette buttons if you find picking one of those preferable to typing a letter.]
Kent Cooper, AIA
Intuos5
Perfect, finally got it working now. Thanks a lot!
And it's nice to be able to edit the alias in the future in case I change my mind.
This isn't really the most user friendly way to create aliases to macros, I'd say it's Autocad's age that is to blame. :cara_guiñando_un_ojo:
0 Me gusta
