LTS XREF
LTS XREF
Message 1 of 11
LTS XREF
When I change the lts of my working drawing, the xref's are being affected to. How can I keep the xrefs from changing when I change my working drawing lts? My xref's are overlay and bind. Thanks
Replies (10)
Message 2 of 11
Alfred.NESWADBA
what is "LTS"?
Effected in wich way?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 11
Line type scale. When I change the line type scale in my working drawing, I don't want my xref aspects to change their line type scale.
Message 4 of 11
paullimapa
If you use ltscale or psltscale to change your linetype scales then they'll also affect the xrefs.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 5 of 11
Thank you. I was hoping there was a way to lock the xref because I use fabrication CADmep and for the dashed lines to look as they need, I set lts to .3 which messes up the xref. To fix the xrefs, I have to open the x files and set the a 40.
Message 6 of 11
paullimapa
An option could be to create a pdf from the xref dwg and then instead of attaching the dwg, you'll attached the pdf.  Then the ltscale/psltscale commands will have no effect on the attached pdf linetype.
Paul Li
IT Specialist
@The Office
Message 7 of 11
That sounds like a good work around. Thank you
Message 8 of 11
paullimapa
Message 9 of 11
Alfred.NESWADBA
I would prefer to create a DWF instead of a PDF as this is faster when used as reference.
Generally I don't understand why LTSCALE is a problem when an XRef is used. As long as you have set MSLTSCALE and PSLTSCALE to 1 then independent from the viewport-scale the linetype scaling should be correct for plot and, if necessary, after _REGENALL.
- alfred -
Alfred NESWADBA
Message 10 of 11
Are you saying that if I change my model space to .1, when I go to print out my drawing from paper space, the X reference lines are not going to be affected?
Message 11 of 11
Alfred.NESWADBA
Not clear what you mean by "change model space to 1"
The settings MSLTSCALE has the meaning if the linetype scaling is controlled by the annotation scale (when modelspace is active)
PSLTSCALE (meant for viewports and layout) set to 1 means that the linetype scaling is automatically calculated in distance of paper, independent from the viewport scale. E.g. if your linetype is defined as 3 units line, 3 units space then this line will show itself (on layout and on plot) in the distance 3/3 in case the viewport scale is 1:1 or 2:1 or 1:2 or ... it does not matter.
When PSLTSCALE is set to 0 then the viewport scale controls the linetype scale, so a viewport 1:1 shows the line 3/3 whereas a viewport 1:2 shows the linetype scale as 1.5/1.5 (paper units).
>>>here<<< is some more description (besides of the help content).
HTH, - alfred -
Alfred NESWADBA
