lsp that extracts file names from excel and inserts into known points of AutoCAD
No aplicable
Part of the CAD departments responsibility is to create a second report from an existing report created in Excel.  Within the excel document are photo's that need to be inserted into the second report that we create.  I'm looking for a lsp that can take the links from the excel file and place them into CAD.  Any and all help is appreciated.
0 Me gusta
Responder
299 Vistas
3 Respuestas
Respuestas (3)
No aplicable
Hello @Anonymous  It would be easier if you could send an example of your .XLS.
Check this link Point Manager.
0 Me gusta
No aplicable
Unfortunately, due to proprietary information, I'm unable to share any of our files which truly limits my abilities to resolve issues within these forums.  However, I do appreciate your assistance but looking at the link you sent me that won't work for what I'm needing in this instance but will come in handy for another.
0 Me gusta
No aplicable
So I'm not sure if this will help, but I use a LSP called "Pointsin" to insert coordinates and texts into a CAD file. We have an excel file given to use by field members, then we clean it up a little bit and save it to a text-tab delimited file. We can then use Pointsin to import the data from the text-tab delimited file into CAD as a block. It works really well for us because we need the text to be associated with certain coordinate points, so if you have a point with the link, it might work for you too.
I think the link below is what we used as a base for our LSP.
0 Me gusta
