Anuncios
Lost selection when using Pan in AutoCAD
No aplicable
I lost my selection when i used pan
@Anonymous,
john.vellek has edited your subject line for clarity: lost selection
Responder
442 Vistas
4 Respuestas
Respuestas (4)
Alfred.NESWADBA
as long as you don't use AutoCAD 2018 this is default, nothing new.
For AutoCAD 2018 that was built in as a new feature >>>click<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
cadffm
Alfred talks about PAN during an object selection, so before the objects are marked.
From 2017 SP1 - Systemvariable SelectionOffScreen
https://knowledge.autodesk.com/de/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2017/DEU/Au.... html
The question is: Do you also talk about it?
Or do you already have marked objects and they lose the marking at PAN?
Then my question would be:
Passes only in layout-viewports or in the modeltab too?
Describe exactly what and where you do, ESC ESC: And then ..?
Sebastian
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 Please add some detail so that i can better understand the issue you are facing.
What exact version of AutoCAD are you using?
Please outline the steps you are using or perhaps create a quick Screencast video to show me.
John Vellek
0 Me gusta
john.vellek
HI @Anonymous,
Did your question get answered? I don't see an update from you so please add a post if you need more assistance with this issue.
John Vellek
0 Me gusta
