Look what you can do in Autocad!
 Hi All
Im new to the site and looking to work with others along the way. I concentrate mostly on mechanical, electrical, electronic & patent prototype designs, dont do houses. Been working on designs for specialized hand trucks for the us market. Friends told me to design in solidworks only, so I thought Id just post my results for them to see. ( I will direct them to this forum today ).
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 This looks pretty slick.
If you like Solidworks you might give Inventor or Fusion 360 a try too.
John Vellek
Hi John
Thanks for your interest in my designs, yep I'm using Inventor as well.
These are really cool development apps to use for CAD design.
Dazzy
A complete redesign of our Hand Truck range using AutoCAD. This one is a 24 volt powered hand truck. The arrows represent the direction of movement on this new design.
A True Powered Multi-Role Hand Truck with our sell sheet.
Thanks AutoCAD for a cool product!
Dazzy
There is quite a lot you CAN do in AutoCAD ... the real question is "SHOULD" you??
BeKirra
Yes, really cool one. I also self-learnt 3d modelling with AutoCAD in my workplace.
And it was very impressive when my 1st model done. Then I built stairs, supports structures, pipe runs and other components, etc.
You could go even further if you can write your own routines.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
