Lofting surface error 114036
FHull
FHull
Issue around lofting surfaces, using guides. Error code 114036. OSNAPs used rigorously - including 3d "Knot"
Screencast included.
0 Me gusta
Responder
Soluciones aceptadas (1)
2.592 Vistas
7 Respuestas
Respuestas (7)
Patchy
Could be self intersecting, let's see your .dwg in 2007 version.
0 Me gusta
cheryl.buck
Autodesk Support
Autodesk Support
Hi @FHull,
Thank you for posting. I don't see a ScreenCast, but can share that most lofting errors are related to intersecting surfaces or an incomplete path for surface to be lofted.  Sometimes it is necessary to zoom in very close on the path to see both.
To mark a solution that answered the question or resolved the issue, click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
0 Me gusta
FHull
Hi Cheryl.
Sorry about the screencast - I don't know what happened with that. I did however record a new one because snaps were used accurately and I wanted to show you the result.
https://autode.sk/39wJrFU
On zooming, the snaps don't appear to be accurate but as you'll see - the loft completes successfully in one case, but not the other. Secondly, as I hover the cursor over one of the "disconnected" arc/splice conjunctions you'll see a ghostly duplicate appear/disappear. The working loft is mine and the one that does not work has been copied from a student. A few other students are also experiencing the same problem. As we are all working from home we have a quite a variety of hardware configurations.
I'll attach the .dwg file used in the screencast as well (2007 format) as requested by "Patchy".
0 Me gusta
Patchy
The reason it can't LOFT because the guides don't touch the boundary of the spoon.
0 Me gusta
FHull
Solución aceptada
Sorry folks - the student had performed the mirror of the spline incorrectly.
I'm still concerned an about the OSNAPs though - and the "ghosted" highlighted selections.
moataz.emam.de
Community Visitor
Community Visitor
i have the same problem error code number is 114036 > any solutions
0 Me gusta
amirhadi_alesadi
Hello all
I still have one problem. When I am trying to use red line in the attached file as a "Guide" I just face an error code and not able to fit the surface to red line. Right now, I lofted 3 selected surfaces to make the bowl but need to expand the bowl to red line. Can you please let me know why "Guide" command in loft is not working? I appreciate your time and expertise.
0 Me gusta
