Message 1 of 12
12:53 PM
I've extracted out into polylines the troubled area. I would like to loft the green rectangle up the z axis with the three blue polylines as a guide into a solid model. The idea I have is to fill the empty corner area with a solid model. Essentially I have extracted the edges of the solid model into the blue, yellow and green wireframe.
I have tried using the loft command however I keep recieveing the "at least two profiles must be selected" error message from the command. Is it possible to do this?
Thank You!
