& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
This is the drawing I am working from to produce the model and drawings
I believe that the textbook exercise is in error... The R70 dimension is not an actual arc as it is the lofted profile between the triangle and ellipse. It is actually elliptical and the plane is not flat for that profile. In a 2D layout I tried to show as in the textbook. In Model Space you will see an additional Flatshot block that I made so the objects would become 2D. Even if I explode the flatshot block the profile is not an arc so it cannot be represented as a radius.
I did however create a 3-point arc along the flatshot profile and it measured R67. My guess is that the Author created a Leader to represent this "bogus" radius. In creating the loft you would not need that radius at all. You would only need the R100 arc (as a guide) to loft the ellipse and triangle to one-another.
Hope this helps?
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
