AutoCAD Forum
Loft command
2 REPLIES 2
438 Views, 2 Replies
Loft command
Hi everyone,
      I was trying to build a car from 2d modelling and then using loft. I connected two lower splines and turned it into solid but now I am not able to use loft on the third 2d spline to connect to the first solid. If i do that then the whole solid gets selected. I know this might be silly but I need help.
Thanks in advance
2 REPLIES 2
Kent1Cooper
Do you have the DELOBJ System Variable set to 1?  That would DELete the OBJects used to define the Loft.  If you set it to 0, they will remain, and you should be able to Loft between the 2nd and 3rd Splines [perhaps with selection cycling to catch the Spline rather than the Solid].
Kent Cooper, AIA
imadHabash
if you try to press Ctrl+select solid edge ( to select the solid boundary )  then select your third 2d spline , any changes ?
Imad Habash
Forma Design Contest
