I am using 2016 AutoCad. I remember in previous versions where if you lock a layer(such as a x-ref background), that you can't select that background while it is locked. For some reason, now I can't do that anymore. My background is locked but I can still select it. I know it won't move, but it is a pain in the butt to look at. Is there an option, where it won't select the locked layer?
Solved by ToddRogers-WPM. Go to Solution.
you can try a couple of these options
CADnoob
the entity is still selected (see properties Window), this only turns off the colored "glare" effect. Anyway, this is not a command also, but a Systemvariable, and it IS documented in the help system of Autocad 2016. 🙂
BR,
Daniel
