I've been doing this for so long I remember tossing out the stone tablet and chisel to try that new-fangled CAD stuff...
Rarely do I come across a glitch that leaves me bewildered. This one has popped up a few times within it seems only AutoCAD 2014 & 2015... and it's happened to a few others here in the office.
Here's the scenario:
I have a drawing that has a border with 3 viewports, each set up at specific scales, 2 on the bottom half of the drawing, one on the upper. One xref has been overlayed in modelspace at 0,0,0 at a scale of 1. All viewports are locked. I zoom to the upper viewport still in paperspace, do a couple of things (add text, etc) then zoom back out. The upper viewport still displays correctly.
Whoa! My bottom 2 viewports have zoomed to a different arbitrary factor. Both went from a scale of 1/192 to an oddball 1/128.6278. Huh?
I checked the viewports... both are still locked. I checked the xref within modelspace... the scale has not changed nor has it been moved.
Your thoughts?
Does AUDIT fix anything? I've occasionally had viewports go wonky -- and the fix has been to delete and recreate the viewport. that particular wonkiness I have not see however...
Audit finds no issues. I can unlock the viewport and correct it's display after the fact. I can delete and re-create if necessary. It would be nice to know what causes this to happen in the first place.
The lack of response makes me glad that I'm not the only one stumped by this.
