Locked Layers not displaying
tswartzfager
tswartzfager
I have a DWG with an XREF on a locked layer. For some reason in a specific DWG the XREFs on the locked layer do not display. The odd part is that this issue only seems to occur for one coworker. He is able to select the XREF and it displays in a plot preview, but in model space it shows as turned off. However, when someone else opens that same DWG it behaves normally. That tells me that it's not a DWG setting, but more likely a system variable. Has anyone run into this? Our settings all appear to be set the same.
Timothy Swartzfager
CAD Monkey Extraordinaire
Civil 3D 2020
Valentin_CAD
@tswartzfager ,
Review the suggestions from this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Kent1Cooper
Not displaying at all, or just very close to not visible?  Look into both the XDWGFADECTL and LAYLOCKFADECTL System Variables, which affect that, and are saved in the Registry so they would be computer- rather than drawing-based.
Kent Cooper, AIA
whitney_jeff
tswartzfager
Thanks Kent, but we tried those and our settings were the same on both PCs. LAYLOCKFADECTL and XDWGFADECTL were both set to 50, yet the XREF was not showing up at all.
Timothy Swartzfager
Civil 3D 2020
pendean
Community Legend
Community Legend
@tswartzfager since none of us have your issues with our own files, you'll need to provide much more detail please: it might be time to start sharing actual DWG files, a video or series of screenshots of your entire AutoCAD program with LAYER and XREF palettes open showing us what you see, plus screenshots of your ABOUT and GRAPHICSCONFIG command pop-ups just to get things started.
If all the above is a challenge (we understand, we are all end users like you with some restrictive client contracts), open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/we...
