lock/unlock attributes
philsogood
philsogood
hello
i have to edit some blocks but i've got 100 or more blocks to edit... it could done by hand but....
well, some of the attributes of the block are invisible and/or constant
how can i make attributes visible and unlock?
ithere was a post dealing about this :
https://forums.autodesk.com/t5/forums/replypage/board-id/706/message-id/951079
@dlanorhhas an idea, unfortunately i need to be in the block to make it works... i'd like to be able to do it from a file
thanks
PHil
dbroad
I edit by hand. 100 should take you 10 minutes or less.  Once edited, wblock them for use in other drawings.
Architect, Registered NC, VA, SC, & GA.
pendean
Community Legend
Community Legend
All the same edit and change? For example all 100 that say ABC now need to read XYZ?
Or something else?
philsogood
hello pendean,
this is exactly this
i can do it by hand but i thought that there was a a secret lisp for this!! 🙂
Phil
pendean
Community Legend
Community Legend
FIND command: explore it. No lisp needed.
